This command configures the restart helper router to terminate OSPFv3 graceful restart when received LSAs would affect the restarting router. This occurs when the restart helper receives an LSA that is flooded to the restarting router or when there is a changed LSA on the restarting router's retransmission list when graceful restart is initiated.
vlan | VLAN. |
all | All VLANs. |
vlan-name | VLAN name. |
area | OSPFv3 area. |
area-identifier | Area identifier. |
restart-helper-lsa-check | Terminate graceful restart mode when there is a change to an LSA. |
LSA check is enabled by default.
This command was first available in ExtremeXOS 21.1.
